주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2396 질문 전체 보기
질문 마감됨
iPhone seemingly stuck in a boot loop - suspecting bad battery.
I have an iPhone 4 that, when connected to power, will display the Apple logo for around 10 seconds before shutting off. It continues to repeat the process. Normally, I would consider this just a boot loop, so I put it into recovery mode. However, I cannot get iTunes to recognize it (tried on a Windows laptop and a Macbook Pro).
Upon disconnecting the iPhone from the computer, the phone immediately shuts off. Holding the lock/power button, I can't get it to do anything when not connected to the charger.
I suspect a dead battery. Can anyone confirm this, or let me know what else might be going on?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
hey. i have the same problem. as soon as i remove the cable it shuts down and i cant do anything. i'm also suspecting a bad battery because the backcase puffed out for about 2 mm directly there where the battery is located. so it seems to me like an extremly dead battery.
already ordered a new one. i'll tell you more after repair.
hope it would solve the prob and it isn't a logic board problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
changed battery now and it works again without any probs!
I tried the same thing with no luck. Continued the problem. I'm afraid my situation might be something logicboard related. Any idea how much Apple charges to fix this stuff? I know it's sometimes a flat all-inclusive repair fee.
댓글 달기
I have exactly the same issue. Iphone 4 wont turn on unless connected to PC, and continually goes through a boot loop. I'm guessing a bad battery.
However, I went one step further. I have one of those battery pack cases, so I put my phone in that. It turns on fine and boots up ok, but itunes will not see it. Shortly after I plug in the USB cable, it reboots and goes back into the boot loop.
If, however, I put it into recovery or DFU modes, then itunes sees it ok. Restoring brings up an error 1394 every time.
I'll replace the battery and see what happens.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 4,331
