주요 콘텐츠로 건너뛰기
The HTC Inspire 4G is the first smartphone available on AT&T Wireless branded as "4G". It's nothing more then an Desire HD locked to AT&T and running AT&T Software.
12 질문 전체 보기
My phone has been damaged by alcohol?
ok so i decided to test out a rumor about bathing your smartphone in isopropyl alcohol beings my phone had a bunch of grit/dirt in it. it work just fine before the bath. now it turns on and it functions with 2 problem tho.1) it has dark blotches all over the display.2) it has trouble reading the sim card(as in it still reads the sim card just poorly) and ideas would be great.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Replace the logic board and display assembly. And never put your phone in a liquid, as it will seriously damage it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
" never put your phone in a liquid, as it will seriously damage it." not quite correct. It is perfectly okay to submerge and phone or electronic component in something like isopropyl alcohol or sterile water. The only thing with isopropyl alcohol is to use a concentration high enough i.e. 90%+ to clean the device. It will displace water and evaporate quickly. Submersion in any of these liquids does not contribute to failure. It also does not destroy plastics etc. It is really not a rumor to use this to clean your phone.
댓글 달기
귀하의 답변을 추가하세요
Scott Darr 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 3,897
