주요 콘텐츠로 건너뛰기
The BlackBerry Z10 is a touchscreen-based smartphone developed by BlackBerry, previously known as RIM.
73 질문 전체 보기
Pins or SIM card contacts are broken on blackberry Z10
SIM card is not recognized and it looks that 1 or 2 pins on the SIM card tray are damaged or broken . Can this be repaired or replaced or all motherboard has to be changed . And where an you buy spare parts for Z10
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 7
댓글 1개
This should be a relative new phone. If you are covered under warranty, I would try that first.
댓글 달기
답변 2개
선택된 답변
Hi Nabil,
Can you figure out if the pins are just damaged or if they are actually broken?
In case the pins are damaged, there might be a chance to simply but carefully bend them back into their original position, for example with a tiny item or tool (e.g. toothpick or mini screw driver). Make sure that you remove the battery first before you try any repair on the sim card reader.
Use this teardown of the Z10 here on iFixit which will help you how to open your phone.
Steffen
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Here is some information on the repair
http://www.mobiledeviceworkshop.co.uk/bl...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Nabil Hamdan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 18,694
