Logic Board Upgrade, MBP 13" mid-2010 to MBP 13" mid-2012
Hi all,
I am wanting to upgrade the logic board on my MacBook Pro 13" (Mid-2010) with the one from the MacBook Pro 13" (Mid-2012). Both laptops have the same model number (A1278). By upgrading, I wish to increase the processor speed, maximum RAM, graphics capabilities, thunderbolt and have USB3.0 capabilities.
Essentially I want to put in this:
MacBook Pro 13" Unibody (Mid 2012) 2.5 GHz Logic Board
(although I'd try to find the i7 2.9GHz model)
And remove this:
MacBook Pro 13" Unibody (Mid 2010) 2.66 GHz Logic Board
Does anyone know if this upgrade would be possible? Would the new board fit correctly into my old MBP body (screw placement etc)? Will all the other connections will be the same (LCD, Battery, Fan, SuperDrive etc etc) or will I need adapters/converters. If so, it wouldn't be worth it. But If the two boards are directly interchangeable without any serious problems, this could be a nice upgrade and would breathe a few more years of life into my laptop!
Thanks in advance for help!
상품
$249.99
상품
$249.99
좋은 질문 입니까?
9 댓글
Hi,
anyone succeeded doing this ?
Mike Tombeur 의
Is there anyone who already tried this?
I also have the same question and intention with Chrisbrown.
Thank you
aurallion 의
also wondering this ? anyone ? :)
mortensenstein 의
Yes, it is possible, I’ve just done it.
Major but not so troublesome issues:
1) The old heatsink (2010) does not fit the new motherboard. You’ve to buy one that fits (2011-2012).
2) The new battery connector faces upward, while the old one faces the battery itself. You have to buy a battery that has a connector that fits this new orientation.
Apart from that, the screw placement is the same.
The display data cable is a bit tricky to be put safely back in place.
Some connectors has a slightly different placement/orientations, but that’s not a problem.
Giacomo Santerini 의
@Giacomo Santerini
Ciao Giacomo so could you confirm you didnt have any compatibility problems as wifi antenna, camera etc beside the battery?
Im about to do the same, mid 2012 i7 into mid 2010 core 2 duo.
Grazie
mbozzi 의
4에 댓글 더 나타내기
