주요 콘텐츠로 건너뛰기
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
Backlight but no display on LCD
I have an ipad 2 that may or may not have been dropped by a child the issue that I am having is that there is nothing being displayed on the ipad, but the backlight is coming on and the ipad is recognized by i tunes i will be disassembling tomorrow any tips if anyone has experienced this problem before would be great.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
Hit the corner of the Ipad2 near the Headphone Jack, this trick worked for me and a few other people on the apple forum.
댓글 달기
답변 3개
I would first check the LCD's connection to the logic board, and the cable's connection to the LCD. If the connections are good, then it's likely your LCD is bad. Be VERY careful when removing the digitizer. If it's not damaged, you don't want to break it when removing it to check the connection, or replace the LCD. Good luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
There are 4 square like ic under the lcd connection
make sure you have all 4
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Try hitting the top left-hand corner(headphone jack) a few times with your palm, it worked for me
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Alec 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 1,519
