주요 콘텐츠로 건너뛰기
Apple의 MacBook Pro 노트북 라인은 전문가 및 파워유저를 위한 제품입니다. MacBook Pro 라인은 MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17" 및 MacBook Pro 17"Unibody를 포함합니다.
20003 질문 전체 보기
My MacBook makes a loud noise during boot up, why?
I've had my MacBook Pro for 4 years now, and lately it has been making an uncomforting sound (usually 2-3 seconds long) that is definitely not a good thing. Any suggestions as to how I can get this fixed?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
To start with - Have you tried cleaning the fans and the heat sink fins? Often junk builds up on the blades making them unbalanced and poor air flow causes them to work harder.
If the sound is coming from the HD then it's getting time to replace it. Run Disk Utility to check the drive. If you can with a second bootable drive defragment your system drive. But make sure you've made a back up before doing anything - just in case!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
If this sound is coming from the hard disk then its not a good thing as it can make you to lose your data. So, i would suggest you to maintain the back up of your all data so that if in case hard drive fails still you will have your in a safe mode.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
After speaking to Apple Customer Support, they advised me that there will always be a sound but if I feel it is louder than it should be I should go into an Apple store.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I would recommend downloading from the Apps Store Temperature Gauge To see what the RPM's the fans are running at and what the thermal sensors are saying. A soft whir is expected when the fans are running at low speed and a louder whir when the fans are running at high speed. Anything else is not normal.
댓글 달기
귀하의 답변을 추가하세요
David 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 13
전체 시간: 8,560
