주요 콘텐츠로 건너뛰기
2010년 중반기 모델 A1278 / 2.4 or 2.66 GHz Core 2 Duo 프로세서
794 질문 전체 보기
Using a hard disk cable meant for a different model
Hi all,
Ive recently had my hard disk cable die on me and im running my macbook of a usb flash disk now. Im using a mid-2010 13" Macbook Pro that uses an Apple Part #: 922-9062 hard disk cable.
The problem I have now is that by mistake, I've ordered Apple Part #: 922-9771 instead that is meant for the 2011 model. My question is, would the part still be compatible or does the problem lie possibly with a different connector that connects it to the logic board?
Thanks in advance
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
선택된 답변
These parts are interchangeable: 922-9062, 922-9771, 923-0104
The cable you ordered will work with the following:
MacBook Pro 13.3" 2.26GHz Core 2 Duo (A1278) - Mid 2009 MB990LL/A GS17336
SKU17336
MacBook Pro 13.3" 2.3GHz Core i5 (A1278) - Early 2011 MC700LL/A SKU173361
GS173361
MacBook Pro 13.3" 2.4GHz Core 2 Duo (A1278) - Mid 2010 MC374LL/A GS17336
SKU17336
MacBook Pro 13.3" 2.4GHz Core i5 (A1278) - Late 2011 MD313LL/A SKU173361
GS173361
MacBook Pro 13.3" 2.53GHz Core 2 Duo (A1278) - Mid 2009 MB991LL/A GS17336
SKU17336
MacBook Pro 13.3" 2.5GHz Core i5 (A1278) - Mid 2012 MD101LL/A SKU173362
GS173362
MacBook Pro 13.3" 2.66GHz Core 2 Duo (A1278) - Mid 2010 MC375LL/A GS17336
SKU17336
MacBook Pro 13.3" 2.7GHz Core i7 (A1278) - Early 2011 MC724LL/A SKU173361
GS173361
MacBook Pro 13.3" 2.8GHz Core i7 (A1278) - Late 2011 MD314LL/A SKU173361
GS173361
MacBook Pro 13.3" 2.9GHz Core i7 (A1278) - Mid 2012 MD102LL/A SKU173362
GS173362
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Mayer,
922-9062's are not interchangeable with 922-9771. The 922-9771 is too short to connect the Logic board to the HDD in a 2009 or 2010 13 inch MBP. I've seen a 2011 13 inch MBP with a 922-9062. It may work, but who knows for how long. Since the cable is too long it wouldn't sit right causing folds.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If you're desperate, you can make the short one reach if you don't use the two 3mm screws that hold the middle of the cable down. I wouldn't advise it. I did it but it failed eventually after a couple of years. 922-9771 (821-1226-A) is too short. Use 922-9062 (821-0814-A) because it is longer.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Lam Hew Tot 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 947
