주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2201 질문 전체 보기
Replaced earpiece but it is still very quiet
I ordered an earpiece for the phone with a new one from here because you could only faintly here whom ever was calling you. After a successful replacement the problem is still present. Not sure what the problem could be.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
try changing the speaker mesh on the front screen
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I cleaned the screen so it def can't be that
댓글 달기
The speaker mesh would not be the problem make sure the gold prongs on the speaker it's self are pointing to the top of the iphone .
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
The contact points are pointing up. Could it possibly be the mic next to the headphone jack that's the problem?
I don't think the mic would be the problem! Have you a screen protecter on the screen? There is screen protectors with no holes for the speaker and cause it to be very quite
i have solved the problem a few times with just replacing the speaker mesh, you could give it a try
replaced the screen like you said and it works like a charm thanks for the help man
댓글 달기
귀하의 답변을 추가하세요
jaronnevi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 355
