주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 모델 i9505는 13-megapixel 후면 카메라 및 5-inch 1080p 화면이 특징입니다.
526 질문 전체 보기
NFC: This Tag Is Not Supported
Hi, whenever I try to scan my new NFC tags that my sis got me from eBay with my S4, it says "This tag is not supported" on 3 different NFC writer apps! I even tried to scan one outside of any app with the same result! Help?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 24
댓글 1개
It works. Thanks. :)
댓글 달기
답변 12개
가장 유용한 답변
Go to swipe menu you get when you swipe the home screen down ( so you can turn on bluetooth and wifi and all that) then turn off nfc tag! It stops the annoying bleeding beeping that drives you crazy everytime you move the poxy thing..................and breathe
해당 답변은 도움이 되었습니까?
점수 16
댓글 11개:
Perfecto!; Mine was under settings, 'Connect and Share' NFC - swipe to off position.
Thanks so much for your help!
Thank you. I even use a galaxy S6 for this issue you solved.
This is about the only answer that was right
Thank you! You saved my life
댓글 6개 더보기
댓글 달기
http://www.themobileindian.com/news/1186...
Samsung's flagship smartphone Galaxy S4 has been incompatible with the first generation TecTiles Near Field Communication tags. Now the company quietly plans to push the TecTiles 2 NFC Tags.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
thanks it was driving me mad
댓글 달기
I get the same message on my main screen when I move the phone. Please let me know what causes it and how to stop it when you know.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Thank you! Thank you! Thank you! Thank you!
Was driving me loopy..
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Thanks for the fix too. But what is nfc tag and how did it turn itself on?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
How do I fix this when I need NFC on to work my smart gear Watch?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Whatis NCF tag I have got
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
i can not use this my nfc tag is not working
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
my nfc keeps beeping on my samsung galaxy s6 keeps beeping i wanna have it on but i dont want to turn it off what can i do to make it stop beeping
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You can just turn off the sound. But the best way is to turn off NFC
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
What is NFC tags and what is it used for???
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had my hotel card/key in my hand and this kept beeping! I googled the code to figure-out what it was and lo-n-behold, it was the key!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jeremy Scalpello 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 16
30일 전: 24
전체 시간: 85,729
