주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
iPhone 4 Middle Frame Replacement
Hey
Hope you can help me here.
Today i've replace an iPhone 4 Middle frame to a new one middle frame.
This is not the first time i do that , but this time , when i was assembling the iPhone i noticed the Buzzer was making a lot o pressure under the front screen and the then the home button stoped to click ( but still working perfect ) , I removed the buzzer and the home comes working perfect again , so the buzzer fit pressure is limiting the Home Button movement . What can it be ?
Hope you can help me please
Regards
Ricardo
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
선택된 답변
The vibrate motor is at the top right-hand corner of the iPhone frame (when looking at the back of the iPhone). It is secured by 2 screws which hold the two springy connectors down on the pads of the volume button/headphone jack flex assembly. This has NO impact on your home button under any circumstance. The home button connects to the charging dock connector, which connects directly to the motherboard. Your issue does not make sense. Is there any other information you can provide to help us answer your question?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
As in buzzer you mean the vibrate motor??
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i think he meant the buzzer [loudspeaker], maybe u forgot to put the metal plate back under the home button
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ricardo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 782
