주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Epic 4G는 Samsung Galaxy S II의 첫 번째 미국 출시 버전입니다. Samsung Galaxy S II Epic 4G Touch라고도 알려져있습니다.
Battery would not charge, replaced it, new one wont charge?
Battery would not charge,replaced it,new one wont charge
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Are you using an AC charger? Checked the cables? Checked the connector?
댓글 달기
답변 3개
가장 유용한 답변
I'm betting its a problem with the charging connector on the phone. I've seen a lot of Samsung phones with the charge port go bad or come loose and not make contact. Unfortunately most of them are machine soldered to the motherboard making it extremely difficult to replace.
Hope this helps
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I have this same problem. It is not the connector, as it shows it's charging (charge light turns on), and when it was plugged in all night, it "charged" to 0%, but the phone stayed on, showing me that it receives power through the cable. It's not the battery, as I checked the battery's health and even bought a new one, and saw the same problems.
It also occasionally charges, but usually not above 70%, and it doesn't consistently charge to the same level. It also doesn't actually charge each time it's plugged in, and there seems to be no pattern over 5 days of when it decides to charge other than that if it is charging, and is disconnected, when plugged back in it will not charge again.
It's a weird issue. Anybody seen this before? I'm guessing its a software/firmware problem, because it's actually getting power.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I chatted with some of the EEs in my office, and we decided that probably the charging circuit in the phone is shot. This means that I will need to charge it externally, so I'll be able to charge it. As far as I know, there is no way to fix this.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
martin galindo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 1,221
