주요 콘텐츠로 건너뛰기
G4 Quicksilver는 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, 그리고 1.0GHz 속도로 출시되었습니다.
49 질문 전체 보기
Putting a 3rd hd in the zip caddy of a g4 quicksilver
I followed the g4 quicksilver teardown sequence( (step 11-12) and I want to add a 3rd hard drive. The drive fits in the zip tray alright but the screw holes on the drive don't line up. Do I need to alter this caddy to make it fit or can it just lay in there?
Thank you.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
가장 유용한 답변
velcro works fine for this type of thing
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
I agree. Ralph +
What is the master-slave relationship of the drives (2 per bus)?
댓글 달기
You should be able to just lay it there, it really isn't going anywhere. You could drill new holes if you wanted too, but it shouldn't be nessicary.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Thanx very much for your answers, I took my Dremel and 'oval'ed the hole out to fit the screw in. But after reassembly, then my old Pioneer 104 optical DVD drive went dead. Ah well, back to the workbench.
thanks and regards,
Crocdog
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Crocdog 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 1,050
