주요 콘텐츠로 건너뛰기
모델 M8407 / 550 또는 667 MHz G4 프로세서
28 질문 전체 보기
질문 마감됨
Can't boot to newly installed hard disk
I've got a new hard disk for the "PowerBook". Im trying to format the new disk using OS X 10.5.4 CD.
I keep getting a message saying "you need to restart your computer. Hold down the power button for several seconds or press the restart button."
Do anyone know how I can get over this issue? I have visited some forum site which have advised me on using option keys methods but these haven't helped?
Many thanks in advanced?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
가장 유용한 답변
Mac OS X v10.5 Leopard requires:
A Mac computer with an Intel, PowerPC G5, or Power PC G4 (867 MHz or faster) processor
512 MB memory or more
A DVD drive for installation
9 GB of available disk space or more
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
thanks for the clarification
Correct + Ralph
So if I get a copy of OS X Tiger will it boot and start the install process?
According to Mactracker your computer will run 10.4.11. Ralph
You do not have the processor speed of 867 MHz to even install 10.5
댓글 달기
How far do you come - does the kernel panic come before you are able to enter the setup or does it come after you formatted the disc ?
how large is the new hard disc ?
did you try to boot in verbose mode ?
maybe this should give you a little bit more information about the error
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
It is a 100GB disk? Kernal panic comes before setup. I tried the verbose mode but it didn't progress to anything? The computer was using a version 1 down to OS X 10.5.4. Would that be an issue?
I've tried formatting the disk using some software to HFS+ but that hasn't made a difference...
leopard on a tiBook ?? - i think tiger is the maximum where the tiBook can go
댓글 달기
again
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Apple specs call for a PPC G4 667 mhz processor or better and 1 gb ram as min. req. it will take about 9 gb hdd space, more like 12 gb when avail. extras are added
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
That's 867 & Apple say's 512
I had a TPB 867 with 1 gig RAM and it worked a charm.
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 1,213
