주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
iPod stuck on pause
Hi I have been using my Ipod in my car, and now I have a problem, it stopped working and I can not do anything with it, it is charged but it is constantly showing pause on the screen, it is not locked, I can not turn it off and the click wheel does not do anything, the screen is lit all the time, none of the controls do anything
regards Roy
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
Is it still being recognized by your computer when you plug it in? If nothing else, remove the battery and then reinstall it and see if it starts back up. If so, try the diagnostics mode and check for any errors.
댓글 달기
답변 1개
connect it to itunes and do a factory restore on it, it may be software corruption, if not strip the device and use WD-40 contact cleaner if this doesnt solve it there may be a chance its the logic board
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
royhill44b 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 1,005
