주요 콘텐츠로 건너뛰기
Model number TF700T released in July 2012. The Asus Transformer Pad Infinity is a Wi-Fi and Bluetooth capable tablet with a 10.1 inch screen and 8MP camera.
How to Replace ASUS Tranformer infinity Digitizer TF700
Hi Everyone,
I smashed the digitizer screen on my TF700, i found a replacement but on disassembly it appears that the front bezel is irriversibly bonded to the digitizer, does anyone know where to buy the bezel i have searched online but can find nothing. Do you think asus would sell the part directly? I dont see any other way to put the tablet back together without the bezel.
Thanks in advance
Chris
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
선택된 해법
I had the same issue - the bezel is extremely thin / lightweight and is bonded to the screen glass with double sided tape. I found I could remove all the old glass and tape with v. careful use of a hot air gun and and a knife blade. BE V CAREFUL WITH THE HEAT - the bezel deforms pretty easily. I then used some double sided tape to restick my new glass and hey - presto... HTH
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I used a hairdryer and a stanley knife to separate all the bits from the plastic, I then used White Spirit to clean the glue off the plastic and Double sided tape to bond it to the new one. I later plugged the lcd cable into the screen while the machine was on and melted the connector.... but that's a different story. Make sure you don't do that bit.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Christopher Contino 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 8
전체 시간: 3,249
