주요 콘텐츠로 건너뛰기
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
157 질문 전체 보기
Why my controller doesn't connect to my PS3?
I spoiled water on my controller and then the arrows were not working. So I open it and cleaned it up but now, it won't connect to my PS3.. the LEDS keeps flashing and flashing...
Could you help me ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 6개
How did you clean it? Did you check the components while you cleaned it?
How I do ? i already tried to reset the controller and its not working with the USB cable ...
all the components are fine they have no breaks or anything
yes, I was wondering how you cleaned it.
with a scott towel
댓글 1개 더보기
댓글 달기
답변 2개
선택된 답변
Nicolas, any time you have any electronic component being exposed to water you are running the risk of shortcircuiting any component. I suggest you totally disassemble the controller, after that soak all the components in high grade, preferably anything of 90% isopropyl alcohol. this will displace all the water that may have collected under any of the components. Air dry it after and re-evaluate. Do keep in mind, that just because the components look okay, their internal function may have failed. Not every short circuited component shows external damage. Scott Towels are great for gross contamination, but most certainly not for the microscopic one.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
you may need to re sync it to the console.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Nicolas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 862
