주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Power on, Apple logo shows for split second then black screen
I am a cellular repair tech and fix many iPhone and Androids daily. 80% of which are iPhones. But I'd have to say this one has me stumped. I dropped my iPhone and broke the digitizer AND lcd. Upon replacing the battery was completely dead and showed the battery logo with the thunder bolt indicating it needed to be charged. The battery logo stayed diplayed the entire time it was charging until it had enough charge to boot up. While booting up the Apple logo appeared for a split second then the screen went black. The phone itself continued to boot up. I can connect to iTunes, play music on my phone, receive calls/texts, answer calls (sliding my finger across where the bar to answer is), but no display at all. I have tried multiple hard resets, factory restores, tampered with the connections while the phone is on, examined the entire logic board and connectors and nothing seems out of place. I have never had an iPhone with this issue. Any suggestions or solutions would be greatly appreciated!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
I would try a screen that you no works mayb the display you have put in is faulty!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have this same problem. I tried it with a screen I know that works and the same problem came up. No backlight.
Could it be the LCD backlight coil that needs to be replaced?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
kodyclarence 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,125
