주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2396 질문 전체 보기
How to Unblacklist My Device?
I purchased an Iphone 4 from gamestop and tried to get a quick prepaid service on it , and was denied because the phone was blacklisted. And being dumb I threw out the receipt smh ....Is there anything I can possibly do to unblacklist it ???
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 달기
답변 5개
선택된 답변
First check it here for black listing: http://www.imei.info/iPhoneBlacklistChec...
If it is indeed blacklisted, take the report to Gamestop (they should have a copy of your receipt) and demand your money back or a replacement iPhone. You did use a credit card to buy it, right? You can also report it to the police but if you are still in possession of it, you will probably have to give it to the police as stolen merchandise.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
You could contact your service center or the network provider.
Imei Track
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
try imeiesnrepair.wix.com/imeiesnrpair I repaired my iphone 4s ,not sure if they do 5 or 5s
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I used UnlockBoom service to unblacklist my iPhone. It worked fine for my verizon iPhone 4s.
댓글 달기
yes I have the same problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i have a iphone that i bought off a family member and it is blacklisted i need to be able to get a cheap fix on this please help
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Matt T 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 23,120
