주요 콘텐츠로 건너뛰기
1.6, 1.8, 또는 2 GHz G5 프로세서
20 질문 전체 보기
Why suddenly herringbone screen
After several years of flawless functioning my iMac suddenly comes out with a coloured herringbone background.
The thing is working as usual, but it's very annoying, and I cannot judge colours anymore
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
1.9 GHz PowerPC 970fx (G5)
Intro Date: October 12, 2005 Disc Date: January 10, 2006
Order No: MA063LL/A Model No: A1144 (EMC 2081)
Subfamily: iSight Model ID: PowerMac12,1
Std RAM: 512 MB Std VRAM: 128 MB
Std Storage: 160 GB (7200 RPM) Std Optical: 8X DL "SuperDrive"
Does this look about right?
댓글 달기
답변 2개
선택된 해법
Do you see the pattern and colours when you first start up the computer too, or just while you are in OSX. If you see it all the time, then it sounds like your iMac could be part of a large number of the G5 iMacs that have fallen prone to graphics card failures. These models are notoriously know for having issues with either their capacitors or their video cards. If the issue lies with you graphics card, then the only way to fix it is to replace the logic board. Some people have had success with doing what they call a re-flow of the graphics card, but I would only suggest this is you feel comfortable with taking your mac apart, and at the same time have nothing else to loose. I had 3 of the original G5 iMacs in my household and they have all fallen to graphics card failures. You can probably find a lightly used logic board on eBay if you are really wanting to salvage this mac, most of these older parts are cheap of you look in the right places.
Hope this Helps
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Hi Owen,
Thanks for your reply.
Herringbone there all the time !
Looking like a logic card failure.
Heading for a disaster, as my Power PC G5 is running 10.4.11, the only version accepting my beloved QE passport 6.1 and my costly Nikon Scan with Scan 4 program.
MUST have it repaired, even at high cost.
Will Apple do it ?? (spares out ?) -or do I have to tackle the issue myself ?
Personally I have taken apart a MacBook earlier and not really afraid.
Your advice is MOST welcome
Hans, Copenhagen, Denmark
If you can tell me the iMac's model number, then I cant point out a place where you can get a cheap, lightly used logic board, maybe even new, but it will be something to keep the computer running for longer.
Hi Owen,
Sorry for the delay. Had to go to Zurich on business, but back again to the nagging problem of herringbones. I have studied the incident a little closer. Actually the background of the screen seems to be quite normal , but all icons have the same herringbone structure. As soon as I open an image (photo) the whole photo is fllled with this herringbone effect, and simultanously adding an unwanted hue to the photo.
Apple will not help me. They say the spares for a repair are not available. A small domestic repair-shop will take in my iMac , but I doubt they know what they are doing, (at close to 750 $.)
On eBay I have noticed and read about bulging or even leaking capacitors on the board, I also see offers of groups of capacitors, and even quite a number of different logic boards for sale ( all with different part numbers). There is even a Youtube explanation of how to replace the capacitors.
On iFixit I have seen the steps needed to get into the innards of the monster, which does not seem too difficult – and yet difficult enough – for my taste. But I'm ready for everything now.
The information you ask for goes like this:
17" iMac: MA 063DK/A ( DK because it has a danish keyboard)
Model A1140
serial no W85510XWTAQ ( inside the affected production group) Arghhh
Looking for good new with greatest of interest, and thanks for your efforts
Hans
댓글 달기
해당 답변은 원래 다른 질문에 답변 된 것입니다.
Connect to an external monitor. If you see the same thing on it, you have a video card/logic board issue. If you don't (display is normal) you have an internal display chain: LCD or Cable problem)
If this Answer is helpful please remember to return and mark it Accepted.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Hans Elfelt Bonnesen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 366
