주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Where can I get a replacement wi-fi EMI shield long screw?
Hey all,
I recently brought a iPhone that was in pieces from my friend, I put it back together but I get very poor wifi signal. After looking at it I conclude that this is caused by a missing 4.8mm screw at the top of the iPhone in the EMI shield. I was wondering if anyone knew where I can buy a replacement screw, or if there is another quick fix.
Thanks in advance,
Ryan
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
You can get a whole 47 pc screw set on ebay for only 2 bucks.
The screw you are looking for will be there.
http://www.ebay.com/itm/47-Piece-Full-Sc...
8
Also make sure the silver metal spring on the wi fi antenna cover that the screw goes into is still there and didn't fall off.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ryan vadera 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 509
