주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2201 질문 전체 보기
What to do next? Battery replacement problem.
Ive stupidly tried to remove the battery connection with a flat head screw driver whilst the phone was on. I saw a small spark come from the phone, reassembled it perfectly now it wont turn on. Any idea which component i would have broken?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
Why use a flathead when the screws are + shaped
댓글 달기
답변 2개
선택된 답변
you may test your components independently. The only thing you may hope is not to have endamaged battery connector pins or the logic board. Next time, you'd rather use a plastic knife for example and an anti-static wrist strap. You may find all you need by following the links below.
Hoping to have helped you,
Give us some feedback
Vincent !
[연계 제품이 누락 또는 비활성화 됨: IF145-047]
Digital Multimeter
Digital Multimeter 이미지
상품
Digital Multimeter
$19.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Well by suddenly disconnecting the power, you could have done damage to the software of the iPhone. You should always turn it off to prevent damage and data loss. I would think you may have to replace the battery. Also check to see if anything looks different ie there is an area that has turned black . If thereis gently clean it using isoproyl alcohol not the kind that you have in a medicine cabinet, that has to go low a concentration. Get some with the highest concebtratiom you can get. Then clean the area where u see damage and if that does work the part may need to be replaced.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Vinnie Ebbrell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 167
