주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Water damage no power after clean and battery replacement
Hi all have been working on iPhones for quite a while now and repaired a few water damaged iPhones all which needed cleaned and new battery's.. But I have a water damaged one here now I cleaned it then new battery and nothing tryed a new screen and nothing. its not the backlight as I have checked for a faint image. Unplugged battery and tryed the dock and nothing. Is there any1 that has experience with this shed some light on it?
And the new battery does work have tested it in another phone thank you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Any one have any experience with this??
댓글 달기
답변 2개
선택된 답변
I have experienced some times that the power-button flex have to be replaced after water-damage. Try to unplug the power-button flex and start the phone by inserting the charger.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
my phone is not water damaged but i am having this same problem. i took it apart a left the battery to charge an hour... nothing everything inside is brand new... i tried looking for a faint image also i didnt see anything... the back warms up though so i know current is flowing through somehow... i posted on here with more detail but i will be checking in for some answers...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
con 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 1,054
