주요 콘텐츠로 건너뛰기
Released around 2010, the Dell Inspiron 15R N5010 is a 15-inch laptop with an Intel processor and dedicated ATI Radeon graphics card.
49 질문 전체 보기
How to get WIFI and Bluetooth drivers for dell N5010?
I need the wifi and bluetooth drivers of the dells as i can't get them in any site ....plz any one can help me for finding this.....
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 12
댓글 1개
just visit dell site to download the driver visit https://goo.gl/SSBGrW
댓글 달기
답변 3개
선택된 답변
First you have to know which wifi card is installed on your device but i link you all possible drivers.
Go to this site and click in the menu Drivers&Downloads there you can find all drivers.
http://www.dell.com/support/troubleshoot...
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Apparently seems like your W-LAN card is either disabled from your network connections or may be there is some hard switch which turned off. All you need to go open network and sharing center then click view network connection to make sure that you Wireless connection is not disabled in any case it should have to be enabled.
Other way is to check on your keyboard from top F1 to F12 keys if you can see a Antenna sign on any of key then press that key by pressing Fn key together.
If the problem still persist then I would recommend you to go on your manufacturer`s website to download the latest driver and update your driver. Good Luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Thank you very much/ my laptop is i5 Aspiron N5010-window 7 64 bets
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Raviteja Adusumalli 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 12
전체 시간: 20,589
