주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2201 질문 전체 보기
No service after battery replacement
Hello i recently try to replace the battery on my iphone 4s, and i notice a no service alert on my screen after reassembly, re open again and notice two small capacitor damage, probably with my pry tool, try to glue them back but no success. Please can somebody help?
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Hello!
Although the damage is most likely linked to the signal it also may not be, the capacitors could just as likely be another function of the phone.
Before declaring it logic board damage ensure the antenna is plugged in, it is located just below the battery connector so it could have been knocked out of place. If it is inserted try removing it and reinserting it.
Try the solution suggested and then reply with the results, we will then reevaluate the situation :)
Good luck, I hope this is as difficult as it gets :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Thanks Josh, but unfortunately the little plug under the battery connector is o.k., i did unplug it and plug it back again, cleaned it up with isopropyl alcohol and nothing, i'm afraid that i will have to replace the main board. :(
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yes looking at the picture uploaded the components are on the tracks coming from the antenna which means they are indeed causing the signal issues, If you cannot solder them back on after multiple attempts then the board most likely needs to be replaced, unless you are willing to pay someone to do it for you :(
If you do not want to do that then you could try soldering over where the component used to be which will connect the tracks together completing the circuit and hopefully bringing signal back :)
It may not work but if you're going to replace the board anyway then it's worth a shot, but I suggest having a few attempts soldering the components before attempting, if unsuccessful then decide what to do from there :)
댓글 달기
귀하의 답변을 추가하세요
tony 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 2,290
