주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
How can I assort all the screws of my iPhone 5?
Ok here is my problem. Ive bought an used iPhone 5, with some screws missing. So of course I want to replace those missing screws and bought a package with all the 54 iPhone 5 screws. Does anyone got any idea how I can easily find out which srew has to be add where? I started with assorting the bigger ones, but below 2,5mm its very difficult to see a difference between the srews. Is there maybe a complete overview or model of all iPhone 5 screws? Thanks in advance!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 4개
선택된 답변
I went through this with a 4s where all the screws from two phones got mixed up when a table was bumped. In my case, I bought a set of screws for baseline comparison.
I took a sheet of paper and drew squares, looked at the repair guide, and wrote in each square a size and number of screws. Last, I used a micrometer to measure each screw and place it on/in the square on a piece of paper.
Later, I used a little plastic (think fishing lure holder) clear box and labeled each compartment where I placed screws from a couple extra sets that I had ordered -- never know when you might lose one.
It takes a bit of time but better than shooting in the dark.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
If you go through the iPhone 5 guide list and follow each guide for the areas where the screws are missing, the guide tells you what size each screw should be, a micrometer but be needed.
iPhone 5
Just work through it one be one and you will get there, an important thing to note, if at any time there is a little too much tension on the screw STOP as this will be the wrong screw.
Please let me know how you get on.
Cheers
Brendan Mills
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thats what I tried first, does the guide tell me the length or the size of the screw?
Yes it does, every screw will have a size stated in the guide
댓글 달기
Same happened to me dropped all of them
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Securing and keeping track of those tiny screws:
  1. Before removing any screws from any device:
    • Read through the guide!
    • Write down the each step number that has screw removals
  2. Beside that step number:
    • Write the screw sizes
    • Write totals for each size
  3. Create a “tack strip”:
    • A strip of masking tape, long enough for each step with screw removal
    • Secure the “tack strip”your work surface, STICKY side UP
  4. I secure the “tack strip” to the work surface along its top and bottom with more masking tape pieces.
  5. On the top strip:
    • Write the step number
    • Write the other info about the screws
  6. Draw a line from the top strip, across the “tack strip”, and all the way to the bottom strip.
Additional tip: Do not work over a carpet! ;+)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Rob 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 11,538
