주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
iPhone 4s will not power on...
OK, so its been a while since i used my iphone 4s. its been in parts for about a year and I just recently bought all new hardware for it. The hardware I replaced goes as follows:
Proximity sensor
Home Button cable
Charger port
Battery
LCD Screen
I pretty much replaced everything in relation to power. I kept it on the charger for about atleast an hour. At most, the IC's under the camera warms up, but no other responses. The computer doesn't even read it, which is how i know it has not powered on. There was no water damage because i strictly took it apart to replace the exterior, but just got lazy. I also tried researching the schematics, perhaps I can try to find out where the flow of electricity stops, but its really hard to find. Looking for suggestions...
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
Right now i have no clue what to do...
after researching, i think my battery connector might be faulty... i will check and continue to update...
댓글 달기
답변 1개
가장 유용한 답변
I truly think that your problem is the same as mine! In my opinion it's either the mother board that has a short circuit OR the grounding thingies that are supposed to be mounted a certain way and we're missing it...
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
in desparation im gonna try placing the grounding cables and pray... i miss my iphone :(
댓글 달기
귀하의 답변을 추가하세요
gtcoodyscoops 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 979
