Replace a faulty keyboard key or full assembly
I have a faulty return key that seems to get stuck with the lightest touch. I would like to either remove the key to see what the issue is, or replace the keyboard assembly.
좋은 질문 입니까?
좋은 질문 입니까?
check out this free guide to see if it can help..it's pretty easy to either clean the keyboard of any gunk or replace the keyboard assembly.
해당 답변은 도움이 되었습니까?
Good find. I also found this video break down.
I purchased a new keyboard/touch pad assembly for $10 from ebay and will attempt the replacement as soon as it arrives.
no work
해당 답변은 도움이 되었습니까?
ali, try to ask a question with more than two words. What does not work? What is not working? What have you tried? The better you explain things the greater your chance of getting a meaning full answer.
My whole keyboard is not working anymore. Opened it once just to check inside, but it just made it worse. Previously I only had a few keys not working, now I have almost the whole keyboard.
I think it might be related to the ribbon cable, or even the plug for it on the motherboard. I hope not though.
Know where I can find a new keyboard ?
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 12,169
