주요 콘텐츠로 건너뛰기
The first generation Neon was introduced in January 1994 and manufactured until August 1999. It was available as a four-door notchback sedan and a two-door notchback coupe.
Why wont my engine fire or run?
It will turn over. but it will try to start up on starting fluid. tjen it quits trying to run just turns over. whats wrong??
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
similar problem on our car turned out to be a loose fuel pump connector..
댓글 달기
답변 2개
I would suspect fuel delivery system and the high voltage circuitry.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
It has all kinds of fuel pressure. and yhe high voltage circuitry? how might i check that?
Search this site: bobistheoilguy.com Look in the Automotive and Mechanical forums.
You will also need basic voltmeter and ohmmeter test equipment.
댓글 달기
i have almost the same problem my dodge neon wont even turn over it doesnt even do a click what do i do ? can anhy body help me
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Brandon B 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 403
