What power related component should I replace next?
I accidentally spilled water (from a Dasani water bottle) onto my MBA (on the keyboard) while it was on. I immediately turned it off, wiped any visible water off, held it open and upside down (with keyboard toward floor) to let gravity work it's magic. Then I put it in a large plastic bag with rice and dessicant pouches for 2 weeks.
Unfortunately, OSX indicates it takes roughly 20 hours to charge the battery to 100%, although a more realistic number is around 48 hours.
I've done PRAM and SMC resets and replaced the battery and the I/O board - but still the same problem.
Suggestions?
좋은 질문 입니까?
댓글 1개
Its time to open it up to locate the corrosion build up. You'll likely need to pull the logic board all the way out as the components on the back side got the water.
Dan 의
