주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Home button no longer responding to slight touches
I have had my iphone 4S for awhile and me and my girlfreind have been noticing that my home button is slowly becoming less and less responsive. The home button is requiring more and more force in order to register as a push.
It is currently functioning however the force required is not something i feel comfortable subjecting my phone to on an ongoing basis and double pressing in order to achieve multitasking is horribly inaccurate. it will frequently only register one push of the button
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
My guess is that the Home Button internal pad is worn out. The replacement part is the Home Button Flex cable. The repair requires that the Front Screen Assembly be removed to get to Home Button. A workaround is Assistive Touch. It is set in the Settings App -> General -> Accessibility -> AssistiveTouch -> turn it ON -> press white button on screen -> Home.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It seems the home button connector is loose or the home button is broken. You may have to disassemble the phone to check.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
gabe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 106
