주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
465 질문 전체 보기
Storage Device Upgrade Options
Hi,
Is it possible to upgrade the storage on this 2013 Macbook Air to be like say a 512GB SSD drive? I believe I had found a guide on how to remove the SSD drive. However, could you please also post the various SSDs that we can buy to upgrade this device?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
At this time NO - apparently Apple has once again come up with a proprietary drive/storage system. There are no 3rd party solutions.
The MD711LL/A configuration has flash storage. Neither configuration has a hard drive. The higher-end MD712LL/A configuration also can be equipped with 512 GB of storage at the time of purchase .
*Apple does not intend for one to upgrade the storage after purchase, but it is theoretically possible. As first reported by AnandTech, this model uses a PCIe-based SSD rather than a SATA-connected one. Specifically, it uses a custom Apple design with a "PCIe 2.0 x2 interface, capable of a theoretical maximum of 1 GB/s in each direction."
So you'll have to be patient... OWC generally finds ways to upgrade these machines, but at this time they have not found an alternative.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Anoop Kammaran 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 1,487
