주요 콘텐츠로 건너뛰기
2010년 중반기 모델 A1278 / 2.4 or 2.66 GHz Core 2 Duo 프로세서
794 질문 전체 보기
Keyboard and touchpad with strange behaviour
Hi,
I'm posting here as I've a small problem with a macbook of a friend. The keyboard has a strange behaviour (wrong letters for keys, and of course it's not a language settings problem). I suppose it's a water problem but the touchpad has problems too.
When you move your finger on touchpad top left corner, the touchpad stops working for 2-3 seconds and then works again. I suppose it's a water problem too but how can I check if I have to change both keyboard and touchpad or mother board ? Do you think it could be the motherboard or the keyboard would always take the water first?
I've also read that some people found keyboards on ebay to avoid an all top case replacement. Is it trustable? Do anyone know a good ebay seller?
Thanks in advance !
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Since you have problems with both the keyboard and touchpad the simple DIY solution would be to replace the top case.
A more complex and time consuming one would be to replace the individual parts keyboard and touchpad. Get the proper tools (every job is easier when you have the right tools)- read over the guides - make a decision.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you for your answer, it confirms my diagnostic. I'll change the top case and touchpad then.
Thanks again.
댓글 달기
귀하의 답변을 추가하세요
Gilles Fernandez 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 244
