주요 콘텐츠로 건너뛰기
Apple Time Capsule Model A1302의 수리 및 분해 안내서. 대부분의 정보는 Model A1254에도 적용됩니다.
19 질문 전체 보기
time capsule dead, hard drive possibilities?
My time capsule will not work, I have tried everything. What I want to know, can it be wired just to be an external hard drive? Can I place an OS on it and use it for storage? Reformat? Basically I have pulled it out of the case and want to know has anyone rewired the connections to have it work, it seems a waste to have a TB hard drive and having it sit static.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
선택된 답변
Which hard drive do you have and does it have standard SATA connections?
The hard drive typically found in a Time Capsule is the Hitachi Deskstar, which is sold by Hitachi as a consumer-grade product—the Hitachi Ultrastar is the enterprise version.[13] Apple labeled the drive as a server-grade drive in promotional material for Time Capsule, and also used this type of drive in its discontinued Xserve servers. Apple states that the Hitachi Deskstar meets or exceeds the 1 million hour mean time between failures (MTBF) recommendation for server-grade hard drives.[14]
The 500 GB, first generation Time Capsule shipped with a Seagate Barracuda ES-series drive.[15] More recently, other hard drives such as the Western Digital Caviar Green series,[16] and the Samsung EcoGreen series have been reported.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
If your question was can I connect this HD to my Mac system directly via the universal SATA adapter.
The answer is no, this HD uses a different format. So you can't recover any data from it nor can you prep the HD via your Mac. The AirPort Utility has the needed functions to prep a new HD if you swap it out.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
To further the discussion: My first generation Time Capsule power supply failed, and I bought a new TC. I have removed the old Seagate Barracuda ES hard drive and want to get a power supply so I can retrieve data on it. Can I buy an external power supply of some kind?
Thanks,
Phil
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Paul Hicks 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 2,836
