주요 콘텐츠로 건너뛰기
전문가 및 파워 유저를 위한 Apple의 노트북 라인입니다. 현재까지 맥북 프로 라인에는 13, 14, 15, 16, 17인치 제품이 있으며, 프리 유니바디(오리지널), 유니바디, 레티나 디스플레이, 터치 바, SOC(시스템 온 칩) 디자인으로 구분되는 주요 개선 버전이 있습니다.
20 질문 전체 보기
Overheat? Then shuts off.
My right fan hums when using my Macbook Pro for about 30 mins plus... But when watching videos on my 15" Macbook Pro, the right fan starts to work hard (louder hum). After watching a movie for about an hour the Macbook Pro then turns off.
Anyone experienced this? Or knows the problem?
Here are the specs:
15" MBP (2006 model)
1.83Ghz intel duo core processor
2GB memory
667 MHz bus speed
OSX - Snow Leopard
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 1개
Buy yourself a laptop cooler. My mac had this problem before but once I used this laptop cooler from Amazon, I never had it again. I'm a gamer so I guess that's says it all. It literally solve my problem plus its cheap. http://www.amazon.com/dp/B00ZA0HFSA
댓글 달기
답변 10개
선택된 해법
Is the machine getting very hot? It is possible that the fan is trying to cool the machine but can't so the machine turns off to protect itself. I have seen iBooks with faulty fans that don't turn on because they know they will get very hot very quickly.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
as i'm typing right now the bottom part is warm, both fans are running. but it was just revving up then it came back down. i THINK the fans are what's causing the heat because it's rotating too fast!
댓글 달기
가장 유용한 답변
I had the same problem with an HP laptop. I purchased a USB powered stand with fans for it and the problem was solved. I don't know if it would work for you but those units are inexpensive and generally useful in reducing heat problems in modern laptops. Ralph
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
hey thanks, i'll look into it!
댓글 달기
try installing a fan control application to see if it will help.
http://mac.softpedia.com/get/Utilities/E...
if not you fan could be inoperable and would need to be repaired. If there is an apple store close to you i would stop in for an opinion even if it is out of warranty. They may be able to diagnose the issue and you can then deiced how to address the problem. I would suggest self install for a fan but you will need to set 2-3 hours of time aside to do that.
-Varsity
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
i downloaded that fan control app. what does it do? bc i really can't control the fan speed w/ this app.
i was thinking of bringing it to an apple store, but that'll be my last option b/c they charge an arm and a leg.
you can increase the overall fan speeds inside your computer, i did this for my mother's macbook pro. test it out, if it doesn't help try rj's option or take it to apple.
댓글 달기
well, make sure your airvents are not blocked for starters.
whats your OS version - there have been issues.
older machines and newer software often just does not work reliably (seems like a conspiracy - you upgrade the software and suddenly the computer needs upgrading...)
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
you could always try watercooling - my brother uses it in his Dell, just a plastic tube, aquarium pump and a bucked. I thought he is overdoing it - but if it helps, who is going to laugh?
cuts down portability though
Airvents are open, not blocked. The OS I'm running is Snow Leopard. The machine is a 2006 Model, so almost 4 yrs old.
Here are the specs:
15"
1.83 intel duo core processor
2GB memory
667 MHz bus speed
and you're right, it is a conspiracy, Steve Jobs uses the apple update to mess up the system settings. it's true!! i believe it was one of the itune updates having a conflict w/ an older OSX and the result was the system not starting up, stupid updates...
Yes, Safari 4 broke my iBook!
댓글 달기
Im having the same problem with my MBP
I will try backing up , bring it to apple for check and if it the Fans are the problemi if they are I will replaced them throug IFiXIT and as well a good cleaning in the interior , hope this may help keep my 2006 model for another 3 years as a living room computer.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
sweet, let me know how that goes! seems like we have the same model (i have an 2006 model too!).
댓글 달기
Because your system is most likely out of warrenty, why not open it up, remove all the dust, and apply AS5?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Fan Control 1.2 works great on my Intel MacBook Pro 17" (non-unibody) The settings are in the System Preferences. I set mine to 2500 RPM min and 50 C to 80 C thresholds. Keeps my temperature below 55 C most of the time. It's fantastic. www.lobotomo.com/products/FanControl/
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Snow Leopard is your problem. I work IT support for a small college. We have seen a ton (20-25 machines ) of MacBook Pro's of your "vintage" experiencing overheating problems once upgrading to snow leopard.
Our best solution has been to downgrade to leopard. If you can't do that the fan control software is the best solution
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Check your fans aren't clogged too. Your system log should tell you if the shutdown is caused by heat.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had this same issue where my laptop would suddenly shut off when watching video. I spend months researching and I would hear that it could be the logic board, fan control, hard drive, graphic card, mountain lion, etc. Finally I removed the RAM that I had upgraded back to the stock RAM and it's back to normal. So it looks like my RAM went bad somehow.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Good answer, but this question is over 3 years old and hopefully resolved:-)
old or not, I'm searching the web looking for answers to the same problem.
댓글 달기
답변을 추가하세요
soundchild 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 13
전체 시간: 60,057
