주요 콘텐츠로 건너뛰기
1.5 Core Solo, 1.66 또는 1.83 Core Duo, 또는 1.83 또는 2 GHz Core 2 Duo 프로세서
142 질문 전체 보기
No Sound from Mac Mini!
I have a new problem that involves no sound coming out of the Mac Mini's speakers. When i received my Mini from the seller there was a gap to the rear of the unit as the party before me did not reassembly the top cover all the way. I gave it back to have the cover fitted correctly and now after powering on the unit I recognise that there is no sound, and plugged in some external speakers and got sound for just about 2mins then a lot of static. I then purchease a putty knife filed the edges and opened the case, but I found nothing that seemed like it was out of placeso I reassembeled.
Any suggestions?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 4개
선택된 답변
sounds like a problem with the audio board
maybe you should open the mini again and look if there is something odd with the board or the connection
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
가장 유용한 답변
I had the same problem with a Core Solo machine. Turns out the people who installed some RAM (this was before I discovered ifixit) had not properly seated the ZIF cable in its socket.
Steps 7 and 8 in the Audio Board install (Mac mini Model A1176 Audio Board Replacement) are where the solution lies.
There is a painted line on the ZIF cable. Before you close the cable lock, make sure the cable is fully inserted - the painted line will be about 1mm above and parallel to the top of the socket. Push down the clip and all should be well.
해당 답변은 도움이 되었습니까?
점수 5
댓글 1개:
this was it for me, SSD was installed by previous owner and the ZIF cable was re-seated BEHIND the actual connecter! Phew :)
댓글 달기
I had the same problem with my MAC MINI A1176 Audio Board so instead of opening the case again I have scarified 1 USB socket and inserted a USB audio divice and it works just fine.
a internal can cost a 30 $ on eBAY but a USB dive can cost you 5 $.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Thanks Gary, this was exactly it!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Robert Antoine 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 18
전체 시간: 11,340
