주요 콘텐츠로 건너뛰기
Samsung Captivate는 Super AMOLED 스크린, 1GHz 프로세서, 확장 슬롯이있는 16GB 온보드 메모리가 특징입니다.
13 질문 전체 보기
Can the board go bad for the antenna?
I threw my phone and broke the screen but had that replaced but now it goes from full service to no service, could it be the antenna board? I took it apart and there is no visible to the board or the antenna but? Im just not sure if I should spend the money on a replacement antenna or not? Please help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
If you are not planning on buying a new phone than yes you have to go for replacement antenna. But before you replace the antenna try reinstalling the OS of your smart phone.
Or try a factory reset after saving your phone data and see if on-board antenna picks up the signal.
Good Luck!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I had the screen fixed through Rogers so when I got the phone back and had the signal problems I took it back to the store and the girl tried a few things with it including replacing my sim card but nothing worked and she told me I would have to send it away again to be looked at for repair. but If I can fix it myself I would rather not spend a fortune on it.
댓글 달기
귀하의 답변을 추가하세요
Ashlie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 161
