주요 콘텐츠로 건너뛰기
The Aspire 7741Z is a notebook by Acer with a 17.3" HD widescreen LED-backlit display.
20 질문 전체 보기
Replacing internal hard drive
My external hard drive failed for the 3rd time so I would like to replace the actual internal hard drive. For this device, what type of hard drive should I buy? Is there limitations to the physical size/dimensions and hard disk capacity? What tools do I need to open and how do I go about replacing the hard drive?
Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
Kat, great video on here http://www.youtube.com/watch?v=6k-FnZze3... It's a straight forward task, not to complicated. All you seem to need is a Phillips #1 or #0... remember that when you change the HDD, make a guide for the rest of us. Hope this helps, good luck.
댓글 달기
답변 1개
선택된 답변
IFIXIT doesn't currently have a repair guide for this model. It appears someone has started the guide but didn't get a chance to finish it {how about helping us out}. It's people like you that make IFIXIT what it is.
As to the tools you'll need looking at the other Acer guides it appears you'll only need a Phillips #00 Screwdriver. But until someone documents things you might get a surprise once you get inside. You might want to get the IFIXIT tool kit with the plastic sponger tools.
As far as the HD its' self, looking at a few parts suppliers you'll need a 2.5" 9.5 mm high SATA II HD.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Kat 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 7
전체 시간: 1,664
