주요 콘텐츠로 건너뛰기
Laptops manufactured by Dynabook (formerly Toshiba). Toshiba has since transferred 100% ownership of the laptop business to Sharp.
vertical lines across screeen of notebook toshiba qosmio
The screen of the desktop is crossed by a number (exactly 14) of vertical lines large about 1 millimeter of different colors.The device works well but the vision with those lines troubles me. Agostino Torre
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 3개
선택된 해법
sounds not that great - but let's start with plugging the qosmio to an external monitor to rule the graphics card out.
here is a great comparsion of screen failures - but i think you's is example 2 with more lines.
here are a few guides for the qosmio's
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
This happened to a friend of mine. Try lightly twisting the display frame. If the number of vertical lines changes or if some disappear and new ones appear then you will have to replace the LCD screen.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
The graphics chip on the X505 series and a few others tend to overheat and this causes the solder joints on the motherboard to crack and fail. New motherboards are available on ebay. There are also repair services to reflow the solder joints. You might even be able to repair it yourself with a heatgun like people do with RRoD Xboxes but that's probably above your skill level.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
agostino 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 3,418
