주요 콘텐츠로 건너뛰기
Samsung Galaxy S3는 안구-추적 기능, 늘어난 저장 용량 및 무선 충전 옵션을 갖춘 멀티-터치, 슬레이트-형식 스마트폰입니다.
459 질문 전체 보기
질문 마감됨
Screen Adhesive Replacement - Screen Adhesive failed
I replaced my GS3 screen manually and I removed the old adhesive after removing the old screen. It has been two days since I replaced the screen but the new screen adhesive does not hold the screen in place firmly. I can actually lift the screen if I stick my nail into an specific place.
I would like to know what kind of glue or tape I should buy to stick my screen firmly to the phone's frame. I read that the 3M self adhesive tape is good but I want to get a second option.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
READ DESCRIPTION!
I bought a double sided tape at staples, and put it on top of the old adhesive. It sticked perfectly, but for some reason this made my phone to short circuit, the screen did not turn on again and the phone heated up very fast. I tried removing the tape but it did not work.
If you are using tape on your phone, buy special tape and not some random tape at staples.
댓글 달기
답변 3개
선택된 답변
Buy the precut adhesive stickers it makes for a much more dustproof and precise fit. They stick very well also.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Go to Amazon.com a purchase the double sided tape made by 3M, it's only $2.18,
http://www.amazon.com/Adhesive-Sticker-D...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The professional way to do it is to use UV glue to assure proper bond.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 4,160
