주요 콘텐츠로 건너뛰기
A multi-function laptop released in 2010 by Toshiba. Can be used for leisure, business, or education.
will not power on when button is pushed
laptop was working, but now it wont power on and the hard drive doesn't run either.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
Have you checked your power adapter to make sure it is working? Checked your battery? What have you tried so far to fix it?
댓글 달기
답변 2개
Usually with Toshiba models such as this it's normally comes down to needing a DC jack replacement. Toshiba uses really cheap DC jacks and really cheap HDDs. Like the comment above you should test the charge first to rule that out.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
wassup who is dis
댓글 달기
I have a Toshiba Satellite L655D-SP6003M, when i push the power on button i can hear the fan working and the first two front leds (from letf) turn on, however the screen remains completely black. I have done this without the battery, just plugged the power adapter. Some say i need to replace the motherboard, is there another option?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I've had the same problem. What I did was heat up the CPU (since it's summer I used a blowdryer). Turn it on twice and the second time it booted up. I do suggest getting another laptop, though, as that is what I'm doing. I now realize that this was posted a long time ago and is probably dead, but I hope this answer helps other people.
댓글 달기
답변을 추가하세요
Frank 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 1,302
