주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
질문 마감됨
Screen ripped off completely while battery connected
iPhone was dropped into water by accident. When I took the screen off to remove the battery before putting the phone into a container with desiccant to dry off, the screen ripped completely off, including all 3 flex cables. (i was using a large suction cup and seem to have applied too much force).
Can if put a new display on and have some chance of success? the water damage indicators show only the very top indicator turned red (to indicate damage).
Finally , part of the shield that adjoined the area with the cables also bent up, exposing a small corner of what i believe is the motherboard, but also making it not possible to close the phone (perhaps a little aluminum could be snipped off with the precision snips.)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개:
TedW, any chance you could post a couple of images? I am interested in taking a look at where the flex cables are torn off etc. It will help if we can see what you see.
Thanks for the reply. It will take a couple of days for me to get to the photo as the phone isn't with me at the moment. But as I recall the upper two cables were split in the middle but the one that plugs in lowest was ripped from/at the connector (and somehow in the process must have been the cause of the aluminum being bent in a corner just below it).
I replaced the screen and now it actually works, as far as I could tell so far. I was under pressure to fix the phone (my wife's) so i just went ahead and did it.
I still need to replace the front facing camera, the other two ribbons were part of the new screen. The actual connectors on the phone are fine.
댓글 달기
답변 1개
This is going to be a pricey repair / gamble. If you have insurance on the device put it back together and file a claim. That's just my opinion.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 877
