주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
548 질문 전체 보기
Is it possible to install two 3.5" drives in 2007 iMac?
I've been doing some research about replacing the optical drive with my current hdd and adding an ssd to the original hd slot.
So far I have found that adapters for the optical drive only accept 2.5" drives. Both of the drives I want to use are 3.5". Is it possible to fit 3.5" drives in the hd slot and optical drive bay? If so, do I need a special part to adapt the optical drive to the hdd?
Many thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
NO - the space available is for a 2.5 drive there isnt' an extra inch to be found. study the guide for HD replacement... I have not found a 2008 3.5 optical drive kit for an iMac. If you have one that may be possible there's more room.
I suggest you find the optibay kit first, then the drive that fits it.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
lanceakiyama 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 208
