주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Standard bottom microphone don't work
Like i said in the title, bottom microphone of my iphone 4s don't work. The top one working perfectly. So i can use the iphone only on speaker or with hands free earphone.
When i record something with voice memos, I can hear on recording very low volume radio frequency noise. When I try to talk with someone, they can't hear me, only the same very low volume noise.
I already changed the microphone and nothing happened.
What can I do?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
The bottom microphone is contained in the dock connector part. Replacing it should solve your problem. Here is a link to the replacement guide: iPhone 4S Dock Connector Replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thank you very much. I already changed the microphone and nothing happened. My mistake. Sorry.
In that case, try checking the cable that connects the dock connector to the logic board. Make sure that it is properly seated on the logic board. If it is, you may have to replace it with another dock connector.
댓글 달기
귀하의 답변을 추가하세요
Gicu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 292
