주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
dryer makes thumping sound
When ever we dry clothing, it sounds like there is a shoe in the dryer. Makes a. Thump, thump. Quiet. Then thump thump in that pattern until the load is dry. Any ideas?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
There are several other things it might be, so let us know if this is not it.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Here's what Chumbawamba says to play while doing this repair: https://www.youtube.com/watch?v=2H5uWRjF...
댓글 달기
could be one or more of the fins in the dryer drum is loose.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
where is he fins your talking about
댓글 달기
Me too. Only happens for a short time at start of drying cycle.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Susan did you figure out what the problem was? I am having the same issue
댓글 달기
답변을 추가하세요
Tom 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 10,509
