Can Nexus 5 use battery from LG G2?
Hello,
Nexus 5 and LG G2 are very similar. There is a good chance their batteries are interchangeable.
If so, that would make it a cheap upgrade to 3000mAh for Nexus 5.
Thank you,
Sergey
좋은 질문 입니까?
Hello,
Thank you,
Sergey
좋은 질문 입니까?
Hi Sergey, thanks for the tip! I looked into it a bit, and it looks like the batteries have incompatible connections.
From xda-developers forum, the LG G2's battery has its connection on the top left of the battery:
From our teardown, the Nexus 5 battery connection is on the top right:
해당 답변은 도움이 되었습니까?
Connector is easily moddable. But the real issue is that BL-T7 is 7mm longer - won't fit anyhow. Thank you!
how about the lg g flex battery? looks like the connector is on the same side as the nexus 5 battery...
해당 답변은 도움이 되었습니까?
Would someone tell us the dimensions of the nexus 5 battery and the dimensions of LG G2 battery?
해당 답변은 도움이 되었습니까?
You can see it here http://forum.xda-developers.com/showthre...
24 시간 전: 0
7일 전: 5
30일 전: 5
전체 시간: 17,925
댓글 1개
This question was migrated from http://meta.ifixit.com/Answers.
iRobot 의
