주요 콘텐츠로 건너뛰기
식기 세척기 수리와 분해 안내서 및 지원.
705 질문 전체 보기
Why my dishwasher is stucked in a program?
Hello there, my dishwasher stucked in a program, and don´t receive water or expell it, just make an repetitive and very short noise, like is starting an program (vvvt vvvt vvvvt :))
Hoover Nextra - HND6515A is the model
Ty for all your help
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Thermal Fuse
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn’t overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Door Switch
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Door Latch
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Mine stopped mid program and wouldn't heat the water and so stopped. Not sure if that helps yours, but here is my video of the fix
https://youtu.be/o6vzTzUm7d4
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
megamoka 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 8,366
