주요 콘텐츠로 건너뛰기
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
143 질문 전체 보기
질문 마감됨
How Can I Fix Hard Drive Data Loss Problems
Have you any answer of this problem, so please share the link - Urgent Need!!!!!!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 5개
선택된 답변
If solve this trouble then you need to use best data recovery software that will help you to fix that problem without any issue.
http://www.datarecoverysoftware.windowsd...
http://deleteddatarecovery.pagerankbar.c...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
There are some issues like HDD recovery and problems of bad sectors in the HDD etc are increasing around users. There are many Hard Disk Recovery professional service providers available in market and can be approached easily.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
at first you should try to make an image of your faulty hdd and then
try to recover the data from the image.
every try to recover data from original faulty disk can cause more damage to the disk.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
For an instant solution to recover lost data from Windows System, you can get the help of Kernel for Windows Data Recovery software. It is very advanced and affordable third party software that helps you to recover deleted or lost data from corrupted, damaged, or virus-attacked Windows FAT16, FAT32, NTFS, and NTFS5 partitions. To get more details, visit: http://www.windowsdata.softwarerecovery....
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Seems like it’s too late for the answer but still, if you need to recover files from the hard drive, due to some issues you can use Uneraser from Diskinternals. That software will help you to recover any kind of files.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 706
