Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
344 질문 전체 보기
2nd HD in optical bay versus using 2nd drive kit.
I understand that on 2011 21.5" iMacs you can install a second drive in the empty space behind the Superdrive, and iFixit sells a neat little kit to help you do that.
My question is: if I prefer to remove the Superdrive and install a second drive there with the 12.7mm caddy, is this still possible on this model or has the caddy changed dimensions/specs?
Thank you!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
Not sure why you would want to give up your optical drive when you don't need to. You have a spare SATA port so you're not loosing the function of the optical drive.
In theory it should work. But I don't know of anyone doing this.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Valerio 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 79
