주요 콘텐츠로 건너뛰기
첫 번째 iPhone 모델, Model A1203은 4, 8, 또는 16GB 용량과 알루미늄 뒷면을 가지고 있습니다. 수리를 하려면 상당한 양의 비집기와 납땜을 요구할 수 있습니다.
224 질문 전체 보기
질문 마감됨
Wi-Fi, Bluetooth, sound and microphone not working, what's wrong?
Hello, I've a problem with my iPhone.
When I try to enable Wi-Fi, the write appears grey and says "No Wi-Fi" (PICTURE NR.1)
and it's impossible for me tap it to enter inside the menu.
The same for Bluetooth, the write appears grey and says "Unavailable". (PICTURE NR. 2)
Inside the menu "Settings-General-About" I have no informations about Bluetooth and Wi-Fi (empty fields).
(PICTURE NR. 3)
Are Wi-Fi and Bluetooth manged by communication board?
Are microphone, audio and vibration managed by communication board too?
I know that I'll have to change it cause a broken connector (PICTURES NR. 4)
Thanks so much.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hello it's unlikeley it's the commuincations board but it could be chesck by replacing it (or the cble whatever you think is wrong) if that does'nt fix your problem then could it be (1. It's water dameged or (2. Is there dust inside it?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 174
