주요 콘텐츠로 건너뛰기
A new iteration of the set-top box, a side-set box. Chromecast connects to your Wi-Fi network to stream content from your compatible device to your television.
10 질문 전체 보기
Broken hdmi on chromecast, can it be repaired?
Someone tripped on the wire, snapping the hdmi part nearly off. Now it receives power, but cannot output sound or video. Is there anyway I can repair this?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 15
댓글 달기
답변 12개
가장 유용한 답변
Its a mild long shot, but probably what happened is some of the connections have come loose from the board inside. I bet it broke from the left side, leaving the right side connected as that where the power is. First you'll have to crack it open and see how bad it looks inside. Maybe take a picture if you'd like and send it over and I can judge from there. If it looks possible you'll probably need to make little jumpers from the connector to the board using bits of leftover wire. It won't be fun and you'll need a small tipped solder iron to do some(steady hands help too) but hey you keep it outta the landfill. Good luck.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
A shelf fell on my Chromecast , bent the HDMI connector on it and stopped working. I inspected the hdmi end of the Chromecast and about 7 pins inside that end had bent. I popped the case open, carefully wiggled the black plastic connector off of the pins. Then straightened the pins with a tweezers, carefully reloaded the pins back into the connector. Success! Now it is connected via the short HDMI cable that came with the Chromecast.
Better to be lucky than good.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
would i use a tweezers to connect all of them that came off. pulled 1st gen off tv hdmi head stayed plugged in
댓글 달기
My hdmi chromecast got bent as a L form when my kid pushed the TV backward. Tv was ok.
I crack open the cast and notice that half of the HDMI connection was separated from the cast board. So I bend it back straight making sure that the connections was touching the board properly but did not solder it cause it takes time and extra effort. What I did i added the extension cable that came with the cast and use duck tape to make it stay straight cause it was wobble a little bit.
Glad to say that I have a perfectly working chromecast, the only downside is that is a little bit longer that before cause of the extension cable. But hey I'm happy it works :)
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
This is the part needed to fix it.
uxcell 10PCS 1.0mm Female HDMI Jack Socket 19Pins 4 Legs DIP 180 Degree https://www.amazon.com/dp/B00OKDVMQY/ref...
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Do you have a video on how to replace it?
Thanks for the link, that's exactly the part I needed.
Can anybody tell me the wire diagram for for the male hdmi. I have chomecast 3 . Thanks
댓글 달기
My HDMI connector also came off the chromecast, exposing about 14 wires.
Here's a jpg on Microsoft Onedrive: http://1drv.ms/1wQCtUt
Can someone advice the best course of action?
Thank you.
sfguy2 (at) gmail.com
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Same here. Did you fix it?
댓글 달기
I have this problem with my devise too
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You can buy a new connector and replace it:
http://www.ebay.es/itm/-/192106024898?
Regards!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
it is no more available :(
댓글 달기
Help my problem is that the cable was cut in half, but I had to replace the HDMI connector with a generic one and I need help to join the mini colored cables with the new HDMI as they are not the same color
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
  1. J'ai installé chromecast. Sur netflix et you tube j'ai l'image et le son. Sur d'autres sites notamment de streaming et dailymotion, je n'ai que l'image. Solution. NB j'ai installé l'appli home.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You can buy new HDMI pin and replaced the broken one
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I also have same problem but I able to fix it by replacing the HDMI
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
what's the name of the connector you used?
댓글 달기
Chromecast is not working
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kindal Dewitt 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 18
30일 전: 89
전체 시간: 33,265
